[Qgis-developer] a search plugin
Jože Detečnik joze.detecnik at jkp-sg.si
Wed Feb 15 01:10:02 EST 2012
Very usable plugin. I tested and for me is missing >Zoom to< function which
position search result  and maybe a good aproach will be >Show table<
representing a table with result.
Best wishes, Joze.
[mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Denis Rouzaud
Sent: Tuesday, February 14, 2012 8:50 AM
To: qgis-developer
Subject: [Qgis-developer] a search plugin
Hi all,
I just published a plugin to perform searches in a layer.
I know that for many of you this plugin is just a waste of time since there
is already the SQL advanced search.
I did this plugin for end-users who have pretty much no idea about SQL. With
this plugin, you select a layer, and you can add constraints to your search
using usual vocabulary and also the aliases instead of the field names.
The unique values are listed in an editable combo box for each search item.
You can also save your search to run it later again.
See also the menu to define settings.
Please feel free to comment, and suggest improvements.
http://plugins.qgis.org/plugins/qsearch/
Btw, I cannot fetch plugin repo 1 in qgis today...
Cheers,
Denis
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120215/1948524f/attachment.html
