[Qgis-developer] Re: postgis layers unavailable in Browser (latest master) - "Failed to retrieve layers"
Etienne Tourigny etourigny.dev at gmail.com
Thu Feb 16 12:12:07 EST 2012
Just an update on this issue I found, it seems that postigis tables
that are not in the "public" schema are not available in the browser,
but they are visible in the "Add PostGIS Layer" dialog.
Something must have changed recently in the browser or the postgis
driver - any ideas?
Bug entry is here: http://hub.qgis.org/issues/5022
Regards, Etienne
On Tue, Feb 14, 2012 at 5:58 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> Anybody ???
> Thanks, Etienne
> On Sat, Feb 11, 2012 at 5:33 PM, Etienne Tourigny
>> Hi all,
>> I upgraded my QGis installation yesterday to up-to-date master
>> (549d96c), and all of my postgis layers are not available in the
>> Browser - there is just on item that reads "Failed to retrieve
>> layers".
>> There is not output in the terminal (QGis was started from the commandline).
>> I can add layers from the same DB with "Add PostGIS Layer", and also
>> using the browser with master 0a17ad5  (the older version I kept
>> before the upgrade).
>> Anyone else experiencing this?
>> Thanks, Etienne
