[Qgis-developer] GSoC ideas
Nathan Woodrow madmanwoo at gmail.com
Fri Feb 24 02:55:36 EST 2012
I'm a +1 to Alisters ideas.  I think it would be good to have a full suite
of tools for manipulating vector objects and layers.  These tools should be
ports of fTools to C++ and live in the analysis lib so that they can be
used in C++, Python and UI (Carson and I have talked about this before).
I think this project would be good as it is tightly scoped and would be
easy to mange in chunks. Merging would also be easy, even merging as the
project moves along as each tool is independent.
Would should be careful not to start a GSoC project that is too large, has
wide scope, vague goals, or is to hard to mange in a summer.
- Nathan
On Fri, Feb 24, 2012 at 10:15 AM, Alister Hood
<Alister.Hood at synergine.com>wrote:
> Something that has been mentioned by a few people, and would probably be
> very popular, I described like this:
> "Vector editing/geoprocessing tools or whatever they are called, like the
> ones found in the Mapinfo 'Object' menu - i.e. similar to ftools, but
> taking sets of selected features as inputs, instead of whole layers."
> http://woostuff.wordpress.com/2011/05/17/the-things-i-would-like-to-see-in-qgis-what-are-yours/
> http://lists.osgeo.org/pipermail/qgis-user/2011-May/012041.html
> Later in that second thread someone also mentioned the following; I think
> other people have also made similar requests/suggestions:
> "I guess implementing topology rules and visualizing the existing errors
> would be a way to identify and correct problems like polygon overlapping.
>  It might already exist some code."
> This second idea would probably require more research and thinking about
> exactly what to do.
> I think both these ideas are complementary, and could perhaps be done in a
> single project.  But I guess they are also features that might be able to
> attract other sponsors - you might think it is better to use Google money
> to do something which is unlikely to get sponsorship otherwise.
> Regards,
> Alister
> Somebody started working on a plugin similar to this (early last year I
> think), but it didn't get very far.
> > Date: Thu, 23 Feb 2012 15:31:02 +0100
> > From: jr.morreale at enoreth.net
> > Subject: Re: [Qgis-developer] GSoC ideas
> > To: <qgis-developer at lists.osgeo.org>
> > Message-ID: <ee204f37fdb370744d28a4c105369f70 at enoreth.net>
> > Content-Type: text/plain; charset=UTF-8; format=flowed
> > On Tue, 21 Feb 2012 17:03:15 +0200, Alexander Bruy wrote:
> > > Hi all,
> > > Google Summer of Code 2012 is announced few weeks ago and as far as
> > > I know OSGeo will participate. Hope QGIS will participate too. I
> > > started
> > > wiki page for collecting ideas [0]
> > > Maybe we should announce also to the user list asking for ideas too
> > > [0] http://hub.qgis.org/wiki/quantum-gis/Google_Summer_of_Code_2012
> > Hi,
> > how about these projects :
> > 1. Update and merge the multithread branch
> > 2. QGIS, Valgrind & Co
> > Both would get the student to put its hand in all the dark corners of
> > QGIS and both would produce a positive and visible impact.
> > Regards,
> > Jean-Roc
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120224/57d4de06/attachment.html
