[Qgis-developer] OS X 1.7.4... bomb
Marco Hugentobler marco.hugentobler at sourcepole.ch
Sat Feb 25 15:25:24 EST 2012
Hi William
 >Nokia screwed up compiling their "official" binaries. Everything BUT
QtWebKit works on OS X 10.6 (Snow Leopard).
 >QtWebKit appears to use a OS X 10.7-only system function. This breaks
QGIS help and some plugins on OS X 10.6.
 >It's possible it's not really Nokia's fault. I'll have to compile Qt
myself and package a new QGIS, but there is a
 >bug in Apple's SDK mechanism that could be the problem.
I had the same problem trying to compile Qt 4.8 on OS X 10.5.8. QtWebKit
does not build (compiler error because of reference to 10.7 function)
and QGIS needs Webkit.
How did you solve the problem? Disable the help menu?
Regards,
Marco
On 25.02.2012 16:24, William Kyngesburye wrote:
> So I finally packaged QGIS 1.7.4 (I was waiting on a GRASS 6.4.2 problem, but that may take a while).  And...
> WARNING #1: serious Qt packaging bug
> Nokia screwed up compiling their "official" binaries.  Everything BUT QtWebKit works on OS X 10.6 (Snow Leopard).  QtWebKit appears to use a OS X 10.7-only system function.  This breaks QGIS help and some plugins on OS X 10.6.
> It's possible it's not really Nokia's fault.  I'll have to compile Qt myself and package a new QGIS, but there is a bug in Apple's SDK mechanism that could be the problem.
> WARNING #2: delete existing plugins before running QGIS 1.7.4.  If you can do it before installing QGIS, disable them in the old QGIS, then update and re-enable them one at a time after upgrading QGIS.  If you have already installed 1.7.4, you need to manually delete them from ~/.qgis/python/plugins.
> I've had a report of plugins directly using a specific GDAL version like 1.8 (I don't know how this is possible), which will crash QGIS 1.7.4 which uses GDAL 1.9.  There also appears to be a problem with PyQwt so the profile plugin will crash QGIS.
> Sorry for the breakage.  I'll try to fix things as quickly as I can.
> William Kyngesburye<kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
> Second Pogril: I don't know.  Why IS life like sticking your head in a bucket filled with hyena offal?
> First Pogril: I don't know either.  Wretched, isn't it?
> -HitchHiker's Guide to the Galaxy
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole -  Linux&  Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
