[Qgis-developer] Offset curve tool
Sandro Santilli strk at keybit.net
Wed Feb 29 11:32:49 EST 2012
On Wed, Feb 29, 2012 at 02:45:20PM +0100, Marco Hugentobler wrote:
> Hi Denis
> In certain cases, geos trunk throws an exception (version 3.2 crashes):
> ERROR 1: IllegalArgumentException: RobustDeterminant encountered
> non-finite numbers
> I noticed it happens often with lines with dense vertex
> distributions (e.g. segmented curves). Maybe Sandro (strk) knows
> more about the details?
All I know is I turned it into an EXCEPTION.
Was entering an infinite loop before.
A good start is catching the exception...
If you feel you could also file a ticket on trac.osgeo.org/geos
with a description of the issue and a link to the video.
It's intereting to see how to _obtain_ infinite values during
computation of the offset curve.
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.0 !
  |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
  `-o------'
