[Qgis-developer] Writing new sip files
Stefan Keller sfkeller at gmail.com
Wed Jan 4 09:33:57 EST 2012
Hi Nathan
I'm interested in these SIP files as it seems that you already have
some almost ready.
Can you send me the SIP files you have (even if there are still
errors)? Perhaps we can give you a hand.
I mainly want to "Position on map centered on screen and smoothly
updated by a GPS" with Python (see this thread).
AFAIK it's e.g. class QgsGPSConnection which sends a signal
'stateChanged( const QgsGPSInformation&  info )' as soon as the GPS is
ready.
I already contacted Martin and Marco. Marco offered me to integrate
them into trunk.
Thanks!
Stefan
2011/1/4 Nathan Woodrow <madmanwoo at gmail.com>:
> Hi Martin,
> Attached is my core.sip, I don't think there is anything wrong with it as I
> just copied the line above and changed the name to qgsgpsdectector.sip
> I was going to post a ticket but I thought I might give it a go first.  I
> picked the GPS ones because they looked pretty good in terms of API layout,
> as I didn't want to rearrange to much.
> - Nathan
> On Tue, Jan 4, 2011 at 6:45 AM, Martin Dobias <wonder.sk at gmail.com> wrote:
>> Hi Nathan
>> On Mon, Jan 3, 2011 at 11:19 AM, Nathan Woodrow <madmanwoo at gmail.com>
>> wrote:
>> > Hi all,
>> > I thought this would be a relatively easy thing to do but I seem to be
>> > failing somewhere.
>> well, usually it's simple, though many times sip doesn't report errors
>> in a friendly way, so it's easy to get stuck.
>> > I'm having some trouble creating a new sip file to expose the GPS stuff
>> > to
>> > python.  I have made a sip file to wrap the GPS detector and added it
>> > the
>> > core.sip via %Include qgsgpsdetector.sip but I get a error when running
>> > Make. My qgsgpsdetector.sip and the make error can be found here
>> > http://osgeo.codepad.org/kS63mqND
>> > Anyone know what I might be doing wrong?
>> Hmm, looks like you've made a syntax error in the python/core/core.sip
>> file... I would have to see that one.
>> Generally the easiest way how to get more classes wrapped is to tell me
>> Before wrapping the class I usually try to go through API of the class
>> and improve it slightly if the class is not very python friendly.
>> Martin
> Qgis-developer mailing list
