[Qgis-developer] Re: [Quantum-GIS] Heatmap C++ Plugin (#82)
Tim Sutton lists at linfiniti.com
Tue Jan 10 04:17:25 EST 2012
Hi Marco & all
On Mon, Jan 9, 2012 at 9:53 AM, Marco Hugentobler
<marco.hugentobler at sourcepole.ch> wrote:
> Hi Jean-Roc
>>Marco H. had a patch to set a default file format/compression :
>>http://hub.qgis.org/issues/3436
> True, it still needs to be applied to master branch (modified to go into the
> raster menu instead of the option dialog). There is a larger update for the
> raster terrain module anyway, so hopefully it can be done after that.
Please also see my comments on the pull request:
https://github.com/qgis/Quantum-GIS/pull/82
I think with Marco's patch some of my issues can be disregarded.
Regards
Tim
> Regards,
> Marco
> On 08.01.2012 18:44, MORREALE Jean Roc wrote:
>> Le 08/01/2012 08:25, Paolo Cavallini a écrit :
>>> Il 08/01/2012 05:58, Arunmozhi ha scritto:
>>>> I have written the Heatmap plugin in C++. The plugin presently takes
>>>> in a point layer as input, and the buffer pixel distance and decay
>>>> ratio, and produces a heatmap raster in the ASCII grid file format.
>>>> I hope this makes a good addition in to QGIS plugins.
>>> Thanks a lot Arunmozhi.
>>> Can someone review the plugin to see if it is suitable for pulling into
>>> master?
>>> I think it would make a good addition.
>>> Of course it will be preferrable to generalize the output, alowing the
>>> user to choose the preferred format. This would be useful also for
>>> existing plugins.
>>> All the best.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Dr. Marco Hugentobler
> Sourcepole -  Linux&  Open Source Solutions
> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
