[Qgis-developer] postgres provider refactoring
Jürgen E. Fischer jef at norbit.de
Tue Jan 10 10:02:13 EST 2012
Hi Andreas,
On Tue, 10. Jan 2012 at 15:21:06 +0100, Andreas Neumann wrote:
> Thank you for you work on the PostgreSQL provider.
My pleasure.
> I have troubles with my views which worked before your refactoring. Now  I
> can load the layer, but the geometry is not displayed. I can display  the
> attribute table, but the primary key column is always NULL.
Sounds like a bug.  Can you produce a testcase?   Debugging output might also
help.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
