AW: [Qgis-developer] Problem with setting up PyQGIS (QGIS 1.7.3)
Kaps Stefan stefan.kaps at vorarlberg.at
Thu Jan 12 03:17:37 EST 2012
Hi Jürgen, Gary, Richard etc.
Thanks for your support! My problem was, that I have allready installed python 2.6 for ArcGIS and this caused my problems when running my python script! I am not able to run arcpy 2.6 and pyqgis 2.5 together - has someone experience with arcpy (python 2.6) and pyqgis running together?
Stefan
-----Ursprüngliche Nachricht-----
Von: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] Im Auftrag von Jürgen E. Fischer
Gesendet: Mittwoch, 11. Januar 2012 17:39
An: qgis-developer at lists.osgeo.org
Betreff: Re: [Qgis-developer] Problem with setting up PyQGIS (QGIS 1.7.3)
Hi Stefan,
On Wed, 11. Jan 2012 at 08:52:27 +0000, Kaps Stefan wrote:
> I'm not able to set up the Python environment for standalone
> applications correctly, allthough there are several documentations on
> the internet -> I am using this one
> [1]http://www.qgis.org/pyqgis-cookbook/intro.html#python-applications,
> but
Create a copy of the qgis.bat file in bin and replace the last line with a call your python(w) script in the copy.  That should help.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
