[Qgis-developer] Expression builder in field calculator
Nathan Woodrow madmanwoo at gmail.com
Mon Jan 16 07:44:44 EST 2012
Tim,
Bugger, I'll check it out.
What kind of column was it, int, double?
I had a test with current master and it doesn't seem to have this issue, so
I'll test my branch a bit more.  I didn't change much in that "logic" part
of the calculator mainly just removing old gui references but I'll check it
out anyway.
- Nathan
On Mon, Jan 16, 2012 at 10:09 PM, Tim Sutton <lists at linfiniti.com> wrote:
> Hi
> On Mon, Jan 16, 2012 at 1:01 PM, kimaidou <kimaidou at gmail.com> wrote:
> > Hi Nathan
> > Great news !
> > No objection for me, as it is a great enhancement.
> > Cheers
> > Kimaidou
> > 2012/1/15 Nathan Woodrow <madmanwoo at gmail.com>
> >> Hi all,
> >> I spent some time today adding the new expression builder to the field
> >> calculator.
> >> The current working version can be found
> >> at https://github.com/NathanW2/Quantum-GIS/tree/field-calc with a
> picture of
> >> the current UI attached.
> >> Could I just get a few people to try it out to test I have everything
> >> right, and I'm happy to take any feedback people may have.
> >> If there are no objections I will merge it into master over the next few
> >> days.
> I did a brief test here - using a simple expression:
> "depth" / 3
> applied to the depth field resulted in all nulls. I was expecting it
> to replace the original value - though I'm not sure if that is an
> underlying issue or something introduced with your changes.
> Regards
> Tim
> >> - Nathan
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
>  * QGIS programming and support services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120116/1bb297a2/attachment.html
