[Qgis-developer] GRASS rasters: color table not applied?
Paolo Cavallini cavallini at faunalia.it
Mon Jan 16 10:27:03 EST 2012
Il 14/01/2012 15:13, Radim Blazek ha scritto:
> You can check if the color table is read by grass provider:
>      qgis 2>&1 | grep colorTable
> and it should print something like
> qgsgrassrasterprovider.cpp: 296: (colorTable) Entered
> qgsgrassrasterprovider.cpp: 316: (colorTable) color 1 0 255 0
> qgsgrassrasterprovider.cpp: 322: (colorTable) color 5.5 255 255 0
> qgsgrassrasterprovider.cpp: 322: (colorTable) color 10 255 0 0
tried, no output.
> Probably yes, if possible please attach a piece of your external
> raster if the problem is realy reproducible with that on different
> computers.
OK, maybe I did it too complicated: the r.external command was applied to a .vrt
raster, not to a "real" one.
Also, the very long time to load the raster may be indicative of some problem.
Thanks.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
