[Qgis-developer] Raster resampling
Marco Hugentobler marco.hugentobler at sourcepole.ch
Mon Jan 16 14:55:31 EST 2012
Hi Tim
 >- I noticed a shift (guesstimating in the order of 5-10 pixels) when
 >switching between the interpolation algorithms
Yes, I reduced the shift a bit last Saturday. But there is still a shift
remaining because of double -> int rounding.
There are other known issues with the resampler branch right now:
- With paletted singleband rasters, color changes don't take effect
- There is a small bug with restoring the resampling method
>- with one of my ecw images the computer began to undergo very high
>cpu load with each  zoom / pan event when using bilinear or cubic
>interpolation. Unfortunately the dataset is too large for me to share
>with you right now - I will try to upload it for you when I get a
>chance.
That will be very usefull. I noticed I didn't really test with a layer
containing pyramides.
Thanks for testing,
Marco
On 16.01.2012 17:55, Tim Sutton wrote:
> Hi Marco
> On Tue, Jan 10, 2012 at 12:39 PM, Marco Hugentobler
> <marco.hugentobler at sourcepole.ch>  wrote:
>>> Great stuff Marco - I hope to test your changes soon.
>> Thanks, Tim. The code is not 100% complete, but already testable. Because
>> there are many changes, I'm expecting a large number of bugs. So any report
>> about issues is greatly appreciated.
> I compiled your branch tonight. I havent tested with a lot of data
> sets yet, but two things I immediately noticed were:
> chance.
> Otherwise (with the test images I have used thus far) it creates nice
> smooth tones where before they look pixelated which is great!
> Regards
> Tim
>> Regards,
>> Marco
>> On 10.01.2012 10:29, Tim Sutton wrote:
>>> Hi
>>> On Fri, Dec 30, 2011 at 3:58 PM, Marco Hugentobler
>>>> Hi devs,
>>>> Recently, I've been working on adding raster resampling to QGIS raster
>>>> (http://www.sourcepole.com/raster-resampling-in-qgis). The changes are in
>>>> the branch 'raster_resampler' of my github clone
>>>> (git://github.com/mhugent/Quantum-GIS.git).
>>>> To add resampling in a clean way, I started a bit of refactoring within
>>>> QgsRasterLayer:
>>>> - The new abstract class QgsRasterRenderer is added to replace the
>>>> drawingType switch. The method QgsRasterRenderer::draw() is a replacement
>>>> for the methods drawMultiBandColor(), drawMultiBandSingleBandGray(),
>>>> drawPalettedSingleBandColor(). This should move a lot of code out of
>>>> QgsRasterLayer and reduce code complexity. Currently implemented are
>>>> QgsPallettedRasterRenderer, QgsMultibandColorRenderer,
>>>> QgsSingleBandGrayRenderer
>>>> - The functionality of QgsRasterBuffer to draw the raster layer in
>>>> several
>>>> parts is moved to QgsRasterRenderer base class (same idea of reducing
>>>> complexity in QgsRasterLayer).
>>>> - QgsRasterResampler has two subclasses for now,
>>>> QgsBilinearRasterResampler
>>>> and QgsCubicRasterResampler (maybe average would be useful as well?)
>>>> Any objections or suggestions about this? The code in the branch is
>>>> mostly
>>>> working, but far from being complete.
>>>> I'm going to be without internet connection the next few days, but hope
>>>> to
>>>> get the code to a testable state soon.
>>>> Regards,
>>>> Marco
>>> Regards
>>> Tim
>>>> Dr. Marco Hugentobler
>>>> Sourcepole -  Linux&      Open Source Solutions
>>>> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
>>>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>>> Technical Advisor QGIS Project Steering Committee
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
