[Qgis-developer] Problem with Postgis 2.0 Views and picking (info-tool)
Sandro Santilli strk at keybit.net
Tue Jan 17 18:20:11 EST 2012
On Wed, Jan 18, 2012 at 12:07:46AM +0100, Andreas Neumann wrote:
> Any idea what could be wrong here? Currently I only have a Postgis 2.0
> database available, so I can't test with Postgis 1.5 at the same time.
> Maybe with a virtual machine ...
You don't need a virtual machine. PostGIS 2.0 and 1.5 can cohexist in the
same database cluster. I do have pg14, pg15 and pg20 databases on my
PostgreSQL 8.4 install. There's nothing special to do, install all versions
and only load each of the versions .sql file into each of the target
databases.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
