[Qgis-developer] Problem with Postgis 2.0 Views and picking (info-tool)
Denis Rouzaud denis.rouzaud at gmail.com
Wed Jan 18 01:13:25 EST 2012
Hi Andreas,
I have similar problems, but with Postgis 1.5.
I posted last week on qgis and postgis users:
http://old.nabble.com/MultiPoint-to-CircularString-to-LineString-td33132890.html
In my case, I noticed thaht when building a geometry, you have to
enforce the SRID in it, with EWKT for example. If you don't want to, you
have to feed a -1 for the SRID in the geometry_columns.
If you do not do this (i.e. have a SRID in geometry_columns and nothing
in the view), there is no error in postgis, but you have a problem in
QGIS. I have experienced the same error:
Query: CLOSE qgisf0 returned 7 [ERROR:  current transaction is aborted,
commands ignored until end of transaction block
Hope it helps a bit,
Denis
On 01/18/2012 12:07 AM, Andreas Neumann wrote:
> Hi,
> I recently experimented again with Postgis 2.0 again. I noticed while
> loading the Views works fine, that I cannot pick an object with the info
> tools.
> It works fine with regular tables, but fails for views.
> Here is the error message I get in the log:
> Fetching from cursor qgisf0 failed
> Database error: ERROR:  Operation on mixed SRID geometries
> 1 cursor states lost.
> SQL: CLOSE qgisf0
> Result: 7 (ERROR:  current transaction is aborted, commands ignored
> The error message about the mixed geometries is strange, since the view
> and the project have the same SRID.
> Any idea what could be wrong here? Currently I only have a Postgis 2.0
> database available, so I can't test with Postgis 1.5 at the same time.
> Maybe with a virtual machine ...
> Andreas
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120118/bc85e38e/attachment.html
