[Qgis-developer] Re: Problem with Postgis 2.0 Views and picking (info-tool)
3nids denis.rouzaud at gmail.com
Wed Jan 18 01:15:49 EST 2012
Hi Andreas,
I have similar problems, but with Postgis 1.5.
I posted last week on qgis and postgis users:
http://old.nabble.com/MultiPoint-to-CircularString-to-LineString-td33132890.html
In my case, I noticed thaht when building a geometry, you have to enforce
the SRID in it, with EWKT for example. If you don't want to, you have to
feed a -1 for the SRID in the geometry_columns.
If you do not do this (i.e. have a SRID in geometry_columns and nothing in
the view), there is no error in postgis, but you have a problem in QGIS. I
have experienced the same error:
> Query: CLOSE qgisf0 returned 7 [ERROR:  current transaction is aborted,
> commands ignored until end of transaction block
Hope it helps a bit,
Denis
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-with-Postgis-2-0-Views-and-picking-info-tool-tp7198400p7199171.html
Sent from the qgis-developer mailing list archive at Nabble.com.
