[Qgis-developer] Problem with Postgis 2.0 Views and picking (info-tool)
Andreas Neumann a.neumann at carto.net
Wed Jan 18 07:27:12 EST 2012
Hi Strk,
Thanks for the notice about the possible parallel installations. I heard
about it but wasn't sure if it really works or creates problems.
Thanks for confirming that parallel installations of different Postgis
versions should work fine.
Andreas
On 01/18/2012 12:20 AM, Sandro Santilli wrote:
> On Wed, Jan 18, 2012 at 12:07:46AM +0100, Andreas Neumann wrote:
>> Any idea what could be wrong here? Currently I only have a Postgis 2.0
>> database available, so I can't test with Postgis 1.5 at the same time.
>> Maybe with a virtual machine ...
> You don't need a virtual machine. PostGIS 2.0 and 1.5 can cohexist in the
> same database cluster. I do have pg14, pg15 and pg20 databases on my
> PostgreSQL 8.4 install. There's nothing special to do, install all versions
> and only load each of the versions .sql file into each of the target
> databases.
> --strk;
>   ()   Free GIS & Flash consultant/developer
>   /\   http://strk.keybit.net/services.html
