[Qgis-developer] QGIS on android ALPHA3
Tim Sutton lists at linfiniti.com
Wed Jan 18 08:41:44 EST 2012
Hi
On Wed, Jan 18, 2012 at 11:09 AM, Marco Bernasocchi
<marco at bernawebdesign.ch> wrote:
> Hi all, last night i pushed a new "stablish" version of QGIS for android.
> I've closed some tickets [0] and thanks to an improvement in master (thx
> Jef), now the fontsize problem could be fixed as well (I tested it on an
> asus transformer and it looks great).
> I fixed some widgets as well which are now not too big anymore and can now
> be closed. There still are some widgets that are too big (layer properties
> and raster calculator for example, but we are looking into it.
> As well I worked a bit on the installation, now there should be no more
> first run crash. In this version I temporarly disabled the back button which
> used to crash the app if used. This is not ideal but at least avoids
> crashing your work when hitting that button. This is a necessitas (Qt on
> android) known problem and should get fixed in necessitas alpha4 or beta1.
> As usual you can find all happening around QGIS for android and the
> installer at [1]
> I hope in your feed back and remember that any founding you might have/find
> will help a lot in getting all QGIS on android getting stable faster.
Well done Marco, keep up the great work!
Regards
Tim
> Ciao Marco
> [0]http://hub.qgis.org/projects/android-qgis/activity
> [1]http://android.qgis.org
> Marco Bernasocchi
> www.opengis.ch
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
