[Qgis-developer] error in postgis since
Jürgen E. Fischer jef at norbit.de
Mon Jan 23 02:29:59 EST 2012
Hi Denis,
On Mon, 23. Jan 2012 at 07:43:50 +0100, Denis Rouzaud wrote:
> I think that one of the last postgres updates brought a problem.
Are you using latest master?
> Here is the error I have, in the log, in Postgis tab:
> SQL: DECLAREqgisf9 BINARY CURSOR FOR SELECT asbinary(force_2d("wkb_geometry"),'NDR'),"id"[,etc.] FROM table WHERE "wkb_geometry" && setsrid('BOX3D(x y,x y)'::box3d,21781) AND srid("wkb_geometry")=
> As you can see, there nothing specified for srid("wkb_geometry").
Which srids does the data in the table have?  What's the contents of
geometry_columns?  Can you provide debugging output?
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
