[Qgis-developer] Postgis provider, add and modify linestring
Andreas Neumann a.neumann at carto.net
Mon Jan 23 09:34:47 EST 2012
 for me, the node tool works fine.
 The only missing functionality is to extend a line beyond the end or
 beginning. I am not sure if this can be handled by the node tool or
 requires a separate tool?
 Andreas
 On Mon, 23 Jan 2012 15:31:51 +0100, Marco Hugentobler wrote:
>>Well, as far as I tried, you cannot remove a single node.
>>And to add one, double-click seems to add a node (there is a cross
>> drawn),  but you cannot move it, and it is added in the wrong segment.
> These are probably bugs. The node tool is intended to do exactly
> these things.
> On 23.01.2012 15:27, Denis Rouzaud wrote:
>>> Can't you do that with the node tool?
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
