[Qgis-developer] Postgis provider, add and modify linestring
Denis Rouzaud denis.rouzaud at gmail.com
Tue Jan 24 09:06:41 EST 2012
Hi Jürgen,
Yes, we speak about QGIS core.
I tested with others layers that are straight tables and I do not have
this behavior.
I only have this in a view.
You can see this in the video I posted:
http://www.youtube.com/watch?v=g4IsQ2R_9Ag&hd=1
You probably do not need this, but the SQL of the table and view is here
https://github.com/3nids/qWat/blob/master/sql/pipes.sql
Basically, I have a table and a view with insert/update/delete rules,
including the geometry field.
For info, I use: postgis 1.5.3 and postgres 9.1
Don't know where to look at anymore (already upgrade the packages).
On 01/24/2012 02:52 PM, Jürgen E. Fischer wrote:
> Hi Denis,
> On Tue, 24. Jan 2012 at 11:16:57 +0100, Denis Rouzaud wrote:
>> 2. Have to commit to see the newly added features.
>> I am using a view, and updating corresponding table with a rule. Jurgen,
>> do you have any idea about it? Would it be possible?
> No. That's not the normal behaviour.  How can I reproduce that?  The provider
> shouldn't matter as the new features aren't stored there, but in memory until
> you commit.
> Just to be sure: We are talking about core qgis and not some plugin, are we?
> Jürgen
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120124/87c1b7d3/attachment.html
