[Qgis-developer] Re: QGIS File Paths
Marco Bernasocchi marco at bernawebdesign.ch
Tue Jan 24 12:32:53 EST 2012
For now just click the up one level directory until you get to the root,
from there you can select sdcard.
hope it helps
ciao Marco
On 01/24/2012 06:21 PM, Bryce Davenport wrote:
> From: Bryce Davenport<brycedavenport at gmail.com>
> Subject: QGIS File Paths
> Message Body:
> Dear Marco,
>        I have unproblematically installed QGIS on my cyanogen 7.1 Nook Color, with the only GUI issue being that some of the icons are difficult to access and some of the submenus are too large for the 7" screen. However (and I recall this from your video), the file paths are broken and I cannot load any data to test the program with; my only options when asked to select a file for any of the 'add layer' functions are /data/data/org.qgis.qgis (unaccessible to me through any of the directory managers I've used) or a nebulous 'Computer/' which I assume is default because it cannot read the android file structure. Are there any known workarounds for this? I am a professional archaeologist and was hoping to use this device in the field to save on weight - the only functions I really need are import delimited text layer, interpolate, and extract contours. You have done amazing work so far, and I am glad the GIS community has you as an asset!
> Thanks,
> Bryce Davenport
> This mail is sent via contact form on GIS and Web Tricks http://www.bernawebdesign.ch/byteblog
Marco Bernasocchi
www.opengis.ch
