[Qgis-developer] my first python plugin for qgis
Denis Rouzaud denis.rouzaud at gmail.com
Wed Jan 25 04:29:02 EST 2012
Hi Nathan,
Don't worry, I know people cannot be working full-time on qgis while
being unpayed!
My plugin is Item browser, but is now approved, thanks a lot!
On 01/25/2012 10:19 AM, Nathan Woodrow wrote:
> @SBL your plugin is now approved.  There used to be only a handful of
> people that could approve however I, and a few others, have been added
> to the list to help the task of approving plugins.
> @Denis Bear with us.  Currently there is only one guy working on the
> plugin stuff so he is a little stretched at the moment.  A few of us
> are going to lead a hand where we can in order to help smooth out the
> process.
> For validation yes I think it is useful, but I agree that it should be
> a once off.  Currently if a user is set as trusted then they can
> upload more with auto approve switched on. I'm not sure how many
> people doing the approving knew this.  I'm going to start going though
> and adding users as trusted as I see it is needed
> What was your plugin called?
> Hope this helps
> - Nathan
> On Wed, Jan 25, 2012 at 7:12 PM, Denis Rouzaud
> <denis.rouzaud at gmail.com <mailto:denis.rouzaud at gmail.com>> wrote:
>     Hi Stefan,
>     Yes, the situation is a little bit tricky right now.
>     Creating a project on the hub (i.e. redmine) is not mandatory. But
>     it can be used to host the code repository (as github does) and
>     the issue/bug tracker.
>     Login and create one here if you want: http://hub.qgis.org/projects
>     You will not be able to place it in the plugin project, it should
>     be moved by an admin later.
>     For the validation, I understand your frustration. I uploaded an
>     update 24h ago, and it is not released yet.
>     For all, do you really think that this validation is useful? Maybe
>     for first upload, but then remove it?
>     Cheers,
>     Denis
>     _______________________________________________
>     Qgis-developer mailing list
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120125/654a2735/attachment.html
