[Qgis-developer] Implementing project scales list
rldhont rldhont at gmail.com
Wed Jul 18 00:55:43 PDT 2012
Denis,
In LizMap you can define the scales for your web LizMap project
But with the master, we can reused or override the scales.
René-Luc
Le 18/07/2012 09:53, Denis Rouzaud a écrit :
> Sounds great.
> Would be ideal if web-client uses the project defined scales!
> Greetings
> Denis
> On 07/18/2012 09:50 AM, Alexander Bruy wrote:
>> Hi all,
>> I've pushed this feature to master.
>> Now project scales can be modified from Settings-Options-Map tools
>> (global setting) or in project properties (overrides global
>> settings). Also
>> project setting can be temporarily disabled using checkbox.
> Qgis-developer mailing list
