[Qgis-developer] Implementing project scales list
Denis Rouzaud denis.rouzaud at gmail.com
Wed Jul 18 01:08:00 PDT 2012
Woul be great I think.
The less you have to specify in the client part, the better it is (I think).
On 07/18/2012 10:05 AM, Marco Hugentobler wrote:
> Hi Denis
> Together with Andreas, we are currently thinking about an additional
> way of passing server capabilities to the webclient (something more
> specific than WMS capabilities). Scales defined in the project could
> also be part of it.
> Regards,
> Marco
> Am 18.07.2012 09:53, schrieb Denis Rouzaud:
>> Sounds great.
>> Would be ideal if web-client uses the project defined scales!
>> Greetings
>> Denis
>> On 07/18/2012 09:50 AM, Alexander Bruy wrote:
>>> Hi all,
>>> I've pushed this feature to master.
>>> Now project scales can be modified from Settings-Options-Map tools
>>> (global setting) or in project properties (overrides global
>>> settings). Also
>>> project setting can be temporarily disabled using checkbox.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
