[Qgis-developer] Side by side install on Ubuntu.
Jeremy Palmer JPalmer at linz.govt.nz
Wed Jul 18 15:49:28 PDT 2012
Here's the output for ldd: http://gist.github.com/3139358.
I've also noted that the resource directory is not being found. E.g when I open the coordinate system dialogue I get "Could not open CRS database /resources/srs.db
Error(14): unable to open database file".. The resources seem to be correctly located in /Dev/qgis/install-master/share/qgis
Are there some other environment variables I should be setting?
> -----Original Message-----
> From: Tim Sutton [mailto:lists at linfiniti.com]
> Sent: Thursday, 19 July 2012 7:54 a.m.
> To: Jeremy Palmer
> Cc: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] Side by side install on Ubuntu.
> Hi
> On Wed, Jul 18, 2012 at 12:25 AM, Jeremy Palmer <JPalmer at linz.govt.nz> wrote:
> > Hi Tim,
> > Yes I tried that. Didn't make any difference to the issues below :(
> After doing that, can you run ldd on the qgis binary and its libs
> (qgiscore, gui, python) and see that they are indeed referencing the
> correct libs?
> Regards
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
