[Qgis-developer] How to change splash screen in QGIS 1.8 and where is the location of that splash acreen in qgis 1.8 ?
Volker Fröhlich volker27 at gmx.at
Mon Jul 23 01:16:29 PDT 2012
Am Montag, 23. Juli 2012, 13:44:12 schrieb kranthi kumar:
> can any one tell me how to stop spash screen using --nosplash in
> command prompt ?
> please answer my question as soon as possible
--nologo
qgis --help
Please stop telling people to answer quickly.
Volker Fröhlich
> On 23 July 2012 10:47, kranthi kumar <kranthikumar6789 at gmail.com> wrote:
> > can you please tell how to use -nosplash screen in window ?
> > On 21 July 2012 15:04, kranthi kumar <kranthikumar6789 at gmail.com> wrote:
> >> ---------- Forwarded message ----------
> >> From: kranthi kumar <kranthikumar6789 at gmail.com>
> >> Date: 20 July 2012 18:16
> >> Subject: Re: [Qgis-developer] How to change splash screen in QGIS 1.8
> >> To: Marco Bernasocchi <marco at bernawebdesign.ch>
> >> ok, i will do with your suggestions :)
> >> On 20 July 2012 18:15, Marco Bernasocchi <marco at bernawebdesign.ch> wrote:
> >>> Hi,
> >>> On 07/20/2012 02:35 PM, Nathan Woodrow wrote:
> >>>> You can stop it using --nosplash but you can't change it.
> >>>> - Nathan
> >>>> On Fri, Jul 20, 2012 at 10:31 PM, kranthi kumar
> >>>>> ok thank you..
> >>>>> is there any option to stop the splash screen and through command
> >>>>> prompt and allocating the new image as splash screen ?
> >>>>> On 20 July 2012 17:59, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> >>>>>> It doesn't exist on the file system after QGIS is installed, it is
> >>>>>> compiled into the application.
> >>>>>> - Nathan
> >>>>>> On Fri, Jul 20, 2012 at 10:25 PM, kranthi kumar
> >>>>>>> Thank you for giving reply....
> >>>>>>> actually i am developing one new application,
> >>> So you probably build it yourself no? so change the splash before
> >>> compiling.>>>
> >>>>>>>   for that i need to
> >>>>>>> change the splash screen.
> >>>>>>> in qgis 1.7, splash screen is available in
> >>>>>>> images/splash/splash.png....
> >>>>>>> but now i want to change the splash screen in qgis 1.8
> >>>>>>>   so please tell where is the exact location of splash screen in
> >>>>>>>   qgis
> >>>>>>> 1.8 after installed into the system
> >>>>>>> thanking you
> >>>>>>> On 20 July 2012 17:51, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> >>>>>>>> The splash screen is complied into the resources of QGIS and
> >>>>>>>> currently
> >>>>>>>> can't be changed at runtime.  If you need to change it you must
> >>>>>>>> recompile QGIS.
> >>>>>>>> - Nathan
> >>>>>>>> On Fri, Jul 20, 2012 at 10:18 PM, kranthi kumar
> >>>>>>>>> please do let me know about my question as soon as possible
> >>> as well, it is nice to put the question in the text and not make super
> >>> long
> >>> subjects.
> >>>>>>>>> Regards,
> >>>>>>>>> B Kranthi Kumar,
> >>>>>>>>> Project Engineer,
> >>>>>>>>> C-DAC (R & D)-Pune-411007.
> >>>>>>>>> _______________________________________________
> >>>>>>>>> Qgis-developer mailing list
> >>>>>>>>> Qgis-developer at lists.osgeo.org
> >>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> >>>>>>> Regards,
> >>>>>>> B Kranthi Kumar,
> >>>>>>> Project Engineer,
> >>>>> Regards,
> >>>>> B Kranthi Kumar,
> >>>>> Project Engineer,
> >>> Marco Bernasocchi
> >>> http://opengis.ch
> >> Regards,
> >> B Kranthi Kumar,
> >> Project Engineer,
> >> Regards,
> >> B Kranthi Kumar,
> >> Project Engineer,
> > Regards,
> > B Kranthi Kumar,
> > Project Engineer,
