[Qgis-developer] [Qgis-user] Fwd: qgis 1.8 on MAC: Problem with qwt and more
Etienne Tourigny etourigny.dev at gmail.com
Mon Jul 23 13:50:32 PDT 2012
Sorry, I posted the read-only url without testing, seems it doesn't
work - same thing for other plugins like atlas plugin at
http://qgis.org/git/atlas.git
Can someone please fix this? I have no idea what the read-only git url
is supposed to be.
The developper git repos is at
gitosis at qgis.org:valuetool.git
and the repos browser is at
http://hub.qgis.org/projects/valuetool/repository
In the meantime, I added a zip file at
http://hub.qgis.org/attachments/4719/valuetool-0.4.0.zip
Etienne
On Mon, Jul 23, 2012 at 5:37 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
> On Mon, Jul 23, 2012 at 1:44 PM, Etienne Tourigny
> <etourigny.dev at gmail.com> wrote:
>> Folks,
>> I have developped matplotlib support for the valuetool plugin, if qwt
>> is available it is used as default, but there is an option to use
>> matplotlib instead. Could people please test it so I can release it,
>> perhaps as experimental?
>> It's at the plugin repos http://qgis.org/git/valuetool.git
> Etienne, I can't seem to clone from that url:
> [larrys]$ git clone http://qgis.org/git/valuetool.git
> Cloning into 'valuetool'...
> fatal: http://qgis.org/git/valuetool.git/info/refs not found: did you
> run git update-server-info on the server?
>> I have released a version (0.3.6)  with some other bugfixes in the
>> plugins repos today.
>> Etienne
>> On Mon, Jul 23, 2012 at 10:57 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
>>> Il 23/07/2012 15:56, Werner Macho ha scritto:
>>>> IMHO this tool is worth to be integrated as a core plugin. But I know
>>>> that means a lot of work porting it to cpp.
>>> agreed; it does not need to be ported to C++ to become a core plugin.
>>> all the best, and thanks.
>>> Paolo Cavallini - Faunalia
>>> www.faunalia.eu
>>> Full contact details at www.faunalia.eu/pc
>>> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
