[Qgis-developer] can't see "offset curve" tool under Windows
Marco Hugentobler marco.hugentobler at sourcepole.ch
Tue Jul 24 05:05:20 PDT 2012
Hi Andi, Giovanni
Yes, on Linux, the backbuffer/resize bug on X11 in Qt (still present in
4.8) prevents to have the box moving as widgetitem over the canvas. On
Windows/Mac, the box moves on the canvas with the cursor.
Another idea was to have the interface for the offset tool similar to
the measuring dialog.
Regards,
Marco
Am 24.07.2012 10:37, schrieb Andreas Neumann:
> Hi Giovanni,
> In the box you have to type the distance value and press enter, then
> it will set the value to the exact value you typed. But you have to
> make sure that the mouse is still pressed and not moved. I agree - it
> is a bit difficult to use. Do you have any better suggestions?
> The reason why the box is in the bottom left, is that on Linux there
> can't be a box following the mouse cursor (some XServer limitation). I
> believe that on Windows and OSX the input box follows the mouse - but
> I cannot test it since my Windows version still has the GOES 3.2.x
> Marco Hugentobler is the developer of the tool - maybe he can comment
> on the issues he faced while developing this tool. I am sure he is
> also open to suggestions for improvements.
> Andreas
> On Tue, 24 Jul 2012 08:18:17 +0100, Giovanni Manghi wrote:
>> Hi Andreas,
>> thanks for the explanation.
>> How about my doubt how to use the tool?
>>>> I have also a doubt about how to use the tool:
>>>> when I click on a line on the bottom left corner of the QGIS windows I
>>>> see I can set manually the offset distance, but it doesn't seems to
>>>> have
>>>> any effect. I'm again missing something simple?
>> cheers
>> -- Giovanni --
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
