[Qgis-developer] Error compiling qgis-server
Etienne Tourigny etourigny.dev at gmail.com
Tue Jul 24 15:50:56 PDT 2012
If you comment the function, you will get link errors because the
function was not compiled. Just comment the contents.
I'll try to fix this today and commit to master - are those the only
errors reported?
Etienne
On Tue, Jul 24, 2012 at 7:45 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
>>I don't know anything about qgis server, but shouldn't some gui stuff
>>be disabled when building only qgis server?
> Etienne,
> thx for hint.
> I tried to comment it
> but compiling there is this other error:
>>/home/archivio/tomcat/software/qgis/Quantum-GIS/src/gui/raster/qgsrasterhistogramwidget.cpp:
>> In function âQString
>>findClosestTickVal(double, QwtScaleDiv*, int)â:
>>/home/archivio/tomcat/software/qgis/Quantum-GIS/src/gui/raster/qgsrasterhistogramwidget.cpp:841:
>> error: âmaxâ was not
>>declared in this scope
>>make[2]: ***
>> [src/gui/CMakeFiles/qgis_gui.dir/raster/qgsrasterhistogramwidget.cpp.o]
>> Error 1
>>make[1]: *** [src/gui/CMakeFiles/qgis_gui.dir/all] Error 2
>>make: *** [all] Error 2
> So I following the same ideas , try to remove the code comment all this
> functions:
> findClosestPickVal ,
> QgsRasterHistogramWidget::histoPickerSelected( const QPointF & pos )
> and
> void QgsRasterHistogramWidget::histoPickerSelectedQwt5( const QwtDoublePoint
> & pos )
> After this there was no errore at compile time, but I have an error at
> linking-time
> [ 66%] Building CXX object
> src/gui/CMakeFiles/qgis_gui.dir/moc_qgsquerybuilder.cxx.o
> Linking CXX shared library ../../output/lib/libqgis_gui.so
> CMakeFiles/qgis_gui.dir/raster/moc_qgsrasterhistogramwidget.cxx.o: In
> function `QgsRasterHistogramWidget::qt_metacall(QMetaObject::Call, int,
> void**)':
> moc_qgsrasterhistogramwidget.cxx:(.text+0x1a9): undefined reference to
> `QgsRasterHistogramWidget::histoPickerSelected(QPointF const&)'
> moc_qgsrasterhistogramwidget.cxx:(.text+0x1c8): undefined reference to
> `QgsRasterHistogramWidget::histoPickerSelectedQwt5(QPointF const&)'
> collect2: ld returned 1 exit status
> make[2]: *** [output/lib/libqgis_gui.so.1.9.0] Error 1
> 2012/7/25 Etienne Tourigny <etourigny.dev at gmail.com>
>> All other test environments use high qwt versions, that's why it was
>> not caught.
>> Qwt is a serious pain to support, because of so many different API
>> versions...
>> My advice for now: comment-out the offending line(s), it won't do much
>> harm - the min/max picker will probably not work.
>> Etienne
>> On Tue, Jul 24, 2012 at 6:56 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
>> > I guess yes.
>> > My qwt is 5.1.1.
>> > Unfortunately this is the version available on redhat (i'm using it).
>> > perhaps is allowed disable it for a qgis-server only compile ?
>> > 2012/7/24 Tim Sutton <lists at linfiniti.com>
>> >> Hi
>> >> On Tue, Jul 24, 2012 at 3:35 PM, Andrea Peri <aperi2007 at gmail.com>
>> >> wrote:
>> >> > Hi,
>> >> > try-ing to compile a qgis-server version of qgis ,
>> >> > from latest svn version of qgis and using
>> >> > this settings:
>> >> > with_bindings OFF
>> >> > with_desktop OFF
>> >> > with_mapserver ON
>> >> > I'm having this error:
>> >> > Scanning dependencies of target qgis_gui
>> >> > [ 51%] Building CXX object
>> >> > src/gui/CMakeFiles/qgis_gui.dir/raster/qgsrasterrendererwidget.cpp.o
>> >> > src/gui/CMakeFiles/qgis_gui.dir/raster/qgsmultibandcolorrendererwidget.cpp.o
>> >> > src/gui/CMakeFiles/qgis_gui.dir/raster/qgspalettedrendererwidget.cpp.o
>> >> > src/gui/CMakeFiles/qgis_gui.dir/raster/qgssinglebandgrayrendererwidget.cpp.o
>> >> > src/gui/CMakeFiles/qgis_gui.dir/raster/qgssinglebandpseudocolorrendererwidget.cpp.o
>> >> > In function âQString findClosestTickVal(double, QwtScaleDiv*, int)â:
>> >> > /home/archivio/tomcat/software/qgis/Quantum-GIS/src/gui/raster/qgsrasterhistogramwidget.cpp:833:
>> >> > error: âclass QwtScaleDivâ has no member named âupperBoundâ
>> >> > make[2]: ***
>> >> > Error 1
>> >> > [user at server build-master]$
>> >> > I never seen this error before, probably miss some new dependencies.
>> >> Maybe your qwt lib is too old?
>> >> Regards
>> >> Tim
>> >> > Any hint on this ?
>> >> > thx,
>> >> > Andrea Peri
>> >> > qwerty àèìòù
>> >> > _______________________________________________
>> >> > Qgis-developer mailing list
>> >> > Qgis-developer at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
>> >> Please do not email me off-list with technical
>> >> support questions. Using the lists will gain
>> >> more exposure for your issues and the knowledge
>> >> surrounding your issue will be shared with all.
>> >> Visit http://linfiniti.com to find out about:
>> >>  * QGIS programming and support services
>> >>  * Mapserver and PostGIS based hosting plans
>> >>  * FOSS Consulting Services
>> >> Skype: timlinux
>> >> Irc: timlinux on #qgis at freenode.net
>> > Andrea Peri
>> > qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
