[Qgis-developer] Memory data provider persistence
Chris Crook ccrook at linz.govt.nz
Wed Jul 25 11:03:16 PDT 2012
Hi .. yes I don't like masking the FID field and I'm not thinking this is a long term solution, even before the problem in my implementation with the field index issue (which I think I will be able to fix).  I'm looking at a couple of options over the next few days .. and open to any contributions, suggestions, code, etc :-)
Cheers
Chris
________________________________________
From: haubourg [regis.haubourg at eau-adour-garonne.fr]
Sent: 23 July 2012 20:58
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Memory data provider persistence
Hi Chris, thanks for your feedback. I start thinking using a spatialite is a
great idea. I prefer this than having rules to mask FID field. This can
generate very hard-to-find bugs..
Having a complex Qgs zipfile containing either a spatialite DB or xml + data
would be great but is a big evolution. IMHO, such a break should be kept for
a major version change in QGIS (2.0?).
Is that a work you are on ? Need contributors?
View this message in context: http://osgeo-org.1560.n6.nabble.com/Memory-data-provider-persistence-tp4108012p4989995.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
