[Qgis-developer] Announcing raster-pipes-2 branch for testing
Etienne Tourigny etourigny.dev at gmail.com
Thu Jul 26 06:10:12 PDT 2012
On Thu, Jul 26, 2012 at 3:14 AM, Marco Hugentobler
<marco.hugentobler at sourcepole.ch> wrote:
> Hi Etienne
>> What I have done for the format options is make is a standalone
>> widget, and it is included in the file save as dialog and gdal
>> options, as well as in the gdaltools dialogs (overviews only for
>> illustration). Would we want that for every component, or perhaps have
>> a single widget with optional sections that can be displayed according
>> to context?.
> Embedding is certainly the cleaner solution than disabling sections.
This might lead to much more complex code - with a UI file and class
for each component. Any ideas on how to streamline this?  Perhaps keep
all the c++ code in one file, and have a base class for all components
that has initializing, getting result and signals/slots?
Etienne
> Marco
> Am 25.07.2012 14:00, schrieb Etienne Tourigny:
>> +1 for me also
>> It would be nice to discuss how the file save as dialog should be
>> organised, and how much of it could be reusable.
>> I think that a first candidate for using the file save as dialog
>> components would be gdaltools - see the modified merge tool.
>> Some elements might not be necessary in all use cases.  For example,
>> we could have an overviews section (line in the gdaltools overviews
>> tool), but it would not be necessary in other dialogs.
>> In the case of the full-blown "save as" dialog, all components could
>> be present, but with a ui to hide/display them (with something like a
>> toolbox, tabs, collapsible comboboxes).
>> to context?.
>> cheers
>> Etienne
>> On Tue, Jul 24, 2012 at 3:44 PM, Radim Blazek <radim.blazek at gmail.com>
>> wrote:
>>> On Tue, Jul 24, 2012 at 7:15 PM, Radim Blazek <radim.blazek at gmail.com>
>>> wrote:
>>>> On Tue, Jul 24, 2012 at 4:53 PM, Marco Hugentobler
>>>>> Hi all
>>>>> I think it would be a good move to merge the raster-pipes-2 branch back
>>>>> to
>>>>> trunk. Ok, I know more instabilities, things to polish, etc. But in
>>>>> trunk,
>>>>> it receives more attention and people are more motivated to work on it.
>>>>> Any objections?
>>>> Tests should pass OK before merge, I think. Then +1.
>>> Fixed. Now +1.
>>> Radim
>>>> Do you want to merge everything as a single commit or all commits from
>>>> raster-pipes-2? I would prefer to squash my initial work on pipes
>>>> (87607187-2fdd82f4) into a single commit.
>>>> Radim
>>>>> Regards,
>>>>> Marco
>>>>> Am 20.07.2012 22:15, schrieb Tim Sutton:
>>>>>> Hi
>>>>>> On Fri, Jul 20, 2012 at 10:13 PM, Etienne Tourigny
>>>>>> <etourigny.dev at gmail.com> wrote:
>>>>>>> Ok this is a more general question then - which format(s) should
>>>>>>> raster export support?
>>>>>> It should support any GDAL raster driver that supports write and that
>>>>>> is useable with the active dataset.
>>>>>> I was referring to tif only in terms of the default profiles I
>>>>>> mentioned.
>>>>>> Regards
>>>>>> Tim
>>>>>>> Etienne
>>>>>>> On Fri, Jul 20, 2012 at 5:11 PM, Tim Sutton <lists at linfiniti.com>
>>>>>>> wrote:
>>>>>>>> Hi
>>>>>>>> On Fri, Jul 20, 2012 at 10:07 PM, Etienne Tourigny
>>>>>>>>>> One thing that would be really nice is to have
>>>>>>>>>> some default profiles:
>>>>>>>>>> - options for maximum read performance regardless of disk space
>>>>>>>>>> - options for minumum file size regardless of performance
>>>>>>>>>> - options for 'middle of the road' between the above two
>>>>>>>>> would you have these options for all file types? it could get a
>>>>>>>>> little
>>>>>>>>> complex, but worth the effort. For now I am implementing 1 default
>>>>>>>>> for
>>>>>>>>> each driver, which can be defined by the user.
>>>>>>>> I was thinking just for tiff as I think it is the most generically
>>>>>>>> used.
>>>>>>>> Regards
>>>>>>>> Tim
>>>>>>>>> Etienne
>>>>>>>>>> Regards
>>>>>>>>>> Tim
>>>>>>>>>>>> I have granted you write access, please work directly in
>>>>>>>>>>>> raster-pipes-2.
>>>>>>>>>>> thanks
>>>>>>>>>>> Etienne
>>>>>>>>>>>> Radim
>>>>>>>>>>>>> Etienne
>>>>>>>>>>>>> On Thu, Jul 19, 2012 at 7:21 PM, Tim Sutton
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> Hi
>>>>>>>>>>>>>> On Fri, Jul 20, 2012 at 12:19 AM, Etienne Tourigny
>>>>>>>>>>>>>>> On Thu, Jul 19, 2012 at 4:09 PM, Marco Hugentobler
>>>>>>>>>>>>>>>> Hi Etienne
>>>>>>>>>>>>>>>> Thanks for the feedback, very much appreciated. I've fixed
>>>>>>>>>>>>>>>> these
>>>>>>>>>>>>>>>> issues in
>>>>>>>>>>>>>>>> raster-pipes-2 branch now.
>>>>>>>>>>>>>>>> There are still a few things missing in raster saving:
>>>>>>>>>>>>>>>> - write colortable to output dataset
>>>>>>>>>>>>>>>> - format specific options (e.g. compression)
>>>>>>>>>>>>>>>> - dynamic populating of the format combo box (currently
>>>>>>>>>>>>>>>> hardcoded to
>>>>>>>>>>>>>>>> geotiff)
>>>>>>>>>>>>>>>> - progress indication for tile based saving and possibility
>>>>>>>>>>>>>>>> to
>>>>>>>>>>>>>>>> cancel
>>>>>>>>>>>>>>> It just occurred to me that it would be a great thing to
>>>>>>>>>>>>>>> implement
>>>>>>>>>>>>>>> this as a widget+class in QgisGui, so that it could be used
>>>>>>>>>>>>>>> elsewhere
>>>>>>>>>>>>>>> (e.g. gdaltools, sextante).
>>>>>>>>>>>>>> You mean as a reusable widget like the crs selector? Yes that
>>>>>>>>>>>>>> would be great!
>>>>>>>>>>>>>> Regards
>>>>>>>>>>>>>> Tim
>>>>>>>>>>>>>>> Any way I can help?
>>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>>> Marco
>>>>>>>>>>>>>>>> On 18.07.2012 21:12, Etienne Tourigny wrote:
>>>>>>>>>>>>>>>>> Noticed a few issues with the save dialog
>>>>>>>>>>>>>>>>>     1) "format" drop-down is empty
>>>>>>>>>>>>>>>>> 2) cannot select a new file
>>>>>>>>>>>>>>>>> 3) segfault when saving to an existing file
>>>>>>>>>>>>>>>>> 4) It would be nice to have that action in the legend
>>>>>>>>>>>>>>>>> contextual menu,
>>>>>>>>>>>>>>>>> like for vector layers.
>>>>>>>>>>>>>>>>> regards,
>>>>>>>>>>>>>>>>> Etienne
>>>>>>>>>>>>>>>>> On Wed, Jul 18, 2012 at 3:59 PM, Etienne Tourigny
>>>>>>>>>>>>>>>>>> That's great news!
>>>>>>>>>>>>>>>>>> Concerning raster saving - will there be a mechanism for
>>>>>>>>>>>>>>>>>> compressing
>>>>>>>>>>>>>>>>>> files?
>>>>>>>>>>>>>>>>>> It would be great if default compression schemes could be
>>>>>>>>>>>>>>>>>> chosen for
>>>>>>>>>>>>>>>>>> different file types, and an option at save time - sort of
>>>>>>>>>>>>>>>>>> like image
>>>>>>>>>>>>>>>>>> editors.
>>>>>>>>>>>>>>>>>> I had trouble building it with external spatialite, could
>>>>>>>>>>>>>>>>>> only
>>>>>>>>>>>>>>>>>> get it
>>>>>>>>>>>>>>>>>> to compile with cmake -DWITH_INTERNAL_SPATIALITE=TRUE -
>>>>>>>>>>>>>>>>>> does
>>>>>>>>>>>>>>>>>> this
>>>>>>>>>>>>>>>>>> require a special version of spatialite?
>>>>>>>>>>>>>>>>>> regards,
>>>>>>>>>>>>>>>>>> Etienne
>>>>>>>>>>>>>>>>>> On Wed, Jul 18, 2012 at 12:13 PM, Marco Hugentobler
>>>>>>>>>>>>>>>>>>> Hi devs
>>>>>>>>>>>>>>>>>>> I'd like to announce the branch 'raster-pipes-2' in
>>>>>>>>>>>>>>>>>>> Radims
>>>>>>>>>>>>>>>>>>> repository
>>>>>>>>>>>>>>>>>>> https://github.com/blazek/Quantum-GIS for testing.
>>>>>>>>>>>>>>>>>>> Radim did a great job in refactoring the process of
>>>>>>>>>>>>>>>>>>> reading /
>>>>>>>>>>>>>>>>>>> resampling
>>>>>>>>>>>>>>>>>>> reprojecting / displaying / modifying raster layers.
>>>>>>>>>>>>>>>>>>> Every
>>>>>>>>>>>>>>>>>>> step is now a
>>>>>>>>>>>>>>>>>>> subclass of QgsRasterInterface, with the advantage that
>>>>>>>>>>>>>>>>>>> several steps
>>>>>>>>>>>>>>>>>>> can be
>>>>>>>>>>>>>>>>>>> chained in a QgsRasterPipe. Like that, the raster
>>>>>>>>>>>>>>>>>>> functionality is
>>>>>>>>>>>>>>>>>>> nicely
>>>>>>>>>>>>>>>>>>> separated into different classes and it is easy to
>>>>>>>>>>>>>>>>>>> add/remove
>>>>>>>>>>>>>>>>>>> elements
>>>>>>>>>>>>>>>>>>> in
>>>>>>>>>>>>>>>>>>> the pipe. The iteration over the raster parts is
>>>>>>>>>>>>>>>>>>> controlled
>>>>>>>>>>>>>>>>>>> by
>>>>>>>>>>>>>>>>>>> QgsRasterIterator (because for high-resolution prints or
>>>>>>>>>>>>>>>>>>> analysis on
>>>>>>>>>>>>>>>>>>> large
>>>>>>>>>>>>>>>>>>> datasets, it is impossible to keep everything in memory
>>>>>>>>>>>>>>>>>>> at
>>>>>>>>>>>>>>>>>>> once).
>>>>>>>>>>>>>>>>>>> Please report any issue you find in the branch to the
>>>>>>>>>>>>>>>>>>> developer mailing
>>>>>>>>>>>>>>>>>>> list.
>>>>>>>>>>>>>>>>>>> Besides the changes in code architecture, there is also a
>>>>>>>>>>>>>>>>>>> new
>>>>>>>>>>>>>>>>>>> feature in
>>>>>>>>>>>>>>>>>>> the
>>>>>>>>>>>>>>>>>>> raster-pipes-2 branch. It is now possible to write
>>>>>>>>>>>>>>>>>>> through
>>>>>>>>>>>>>>>>>>> QgsRasterDataProvider (currently only supported by the
>>>>>>>>>>>>>>>>>>> gdal
>>>>>>>>>>>>>>>>>>> provider).
>>>>>>>>>>>>>>>>>>> There
>>>>>>>>>>>>>>>>>>> is a 'save as...' function also for rasters now (though
>>>>>>>>>>>>>>>>>>> it is
>>>>>>>>>>>>>>>>>>> not 100%
>>>>>>>>>>>>>>>>>>> complete at the moment). There is the option to save a
>>>>>>>>>>>>>>>>>>> raster
>>>>>>>>>>>>>>>>>>> in one
>>>>>>>>>>>>>>>>>>> file or
>>>>>>>>>>>>>>>>>>> in tiles (the tiles are then saved in one directory and
>>>>>>>>>>>>>>>>>>> vrt /
>>>>>>>>>>>>>>>>>>> pyramides
>>>>>>>>>>>>>>>>>>> are
>>>>>>>>>>>>>>>>>>> automatically created. Very usefull for saving the
>>>>>>>>>>>>>>>>>>> contents
>>>>>>>>>>>>>>>>>>> of a WMS
>>>>>>>>>>>>>>>>>>> layer).
>>>>>>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>>>>>>> Marco
>>>>>>>>>>>>>>>>>>> Dr. Marco Hugentobler
>>>>>>>>>>>>>>>>>>> Sourcepole -  Linux & Open Source Solutions
>>>>>>>>>>>>>>>>>>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>>>>>>>>>>>>>>>>>>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>>>>>>>>>>>>>>>>>> Technical Advisor QGIS Project Steering Committee
>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>> Qgis-developer mailing list
>>>>>>>>>>>>>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>>>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>>>>>>>>>>>> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
>>>>>>>>>>>>>> Tim Sutton - QGIS Project Steering Committee Member (Release
>>>>>>>>>>>>>> Manager)
>>>>>>>>>>>>>> Please do not email me off-list with technical
>>>>>>>>>>>>>> support questions. Using the lists will gain
>>>>>>>>>>>>>> more exposure for your issues and the knowledge
>>>>>>>>>>>>>> surrounding your issue will be shared with all.
>>>>>>>>>>>>>> Visit http://linfiniti.com to find out about:
>>>>>>>>>>>>>>    * QGIS programming and support services
>>>>>>>>>>>>>>    * Mapserver and PostGIS based hosting plans
>>>>>>>>>>>>>>    * FOSS Consulting Services
>>>>>>>>>>>>>> Skype: timlinux
>>>>>>>>>>>>>> Irc: timlinux on #qgis at freenode.net
>>>>>>>>>> Manager)
>>>>>>>>>> Skype: timlinux
>>>>>>>> Manager)
>>>>>>>> Skype: timlinux
