[Qgis-developer] libqgis_core.so. 1.9.0 missing , how to solve this problem?
Tim Sutton lists at linfiniti.com
Tue Jul 31 05:05:01 PDT 2012
Hi
On Tue, Jul 31, 2012 at 1:53 PM, Yves Jacolin (free) <yjacolin at free.fr> wrote:
> Le 31/07/2012 13:50, 李杨 a écrit :
>> Hello everyone,
>> i building and install qgis on my ubuntu 12.04.  I try on two PC, and both
>> has the similar problem.
>> but when I launch the qgis, le
>> it always say i missing a libqgis_core.so. 1.9.0
>> why this problem occur and how i solve this problem ,
>> further more,
>> where should I go to get answering of similar question?
>> jack at jack:~/apps/bin$ ./qgis
>> ./qgis: error while loading shared libraries: libqgis_core.so.1.9.0:
>> cannot
>> open shared object file: No such file or directory
Alternatively do this before launching QGIS:
export LD_LIBRARY_PATH=/home/jack/apps/lib
/home/jack/apps/bin/qgis
This does not require root permissions.
Tim
> When I get this error I run:
> $ sudo ldconfig
> and qgis is working. But sometime it is not enough.
> As you built QGIS, you need to register before your lib dir /usr/local/lib/
> in /etc/ld.so.conf file. You system will find all lib file in this
> directory.
> Regards,
> Y.
> Yves Jacolin
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
