[Qgis-developer] GGL2 - QGIS integration
Víctor González victorzinho at gmail.com
Mon Jun 18 02:03:06 PDT 2012
Yes, exactly. We plan to implement the same behavior as in gvSIG. You can
see this in some videos.
Referencing GIS layers: http://www.youtube.com/watch?v=tHJ3pFHHe6U
Adding new layers: http://www.youtube.com/watch?v=qcTTUMGuL5Q
We know that it could also be interesting to use GGL2 from within Qgis,
integrating with Sextante. But as Fernando said, it is out of the budget so
it will have to wait a little more.
Víctor.
2012/6/18 G. Allegri <giohappy at gmail.com>
> Regarding your question, that is the idea. But actually the Qgis plugin
>> will be the server since all the communication is started by the GGL2
>> environment. This plugin can be seen as a layer server that provides and
>> "stores" (draws) layers: it opens a socket and manages the requests.
> Hi Victor,
> I've just given a rapid look to the GGL2 site and docs. If I understand it
> correctly, GGL2 will run in its own process, and the Qgis plugin will be
> the intermediary to expose QGis to GGL2 (through socket communication) as a
> "GIS provider".
> The GGL2 commands will run on GGL2 which will be able to reference the
> layers (and the drawing) on QGis through the plugin. Right?
> giovanni
>> Regards,
>> Víctor.
>> Appart of the UI, a qgis plugin must be created that exchanges
>>>> messages with the GGL compiler in order to show results and inform the
>>>> compiler about the layers loaded in qgis, etc. This approach already
>>>> works in gvSIG. You can see how does it looks like from the user point
>>>> of view here[2] and the technical details here[3].
>>> AFAICS, GGL will be used as a server to which the Qgis plugin will talk
>>> through kind of an XML-RPC protocol, is it right?
>>> giovanni
>>>> I hope I've answered your question.
>>>> Regards.
>>>> [1] http://www.gearscape.org/html/course/ejemploggl.htm
>>>> [2] http://www.gearscape.org/html/ggl2/tutorials/gis_interaction.html
>>>> [3] http://www.gearscape.org/html/ggl2/dev/gis_connection.html
>>>> On Mon, Jun 18, 2012 at 9:20 AM, Paolo Cavallini <cavallini at faunalia.it>
>>>> wrote:
>>>> > Il 18/06/2012 09:14, Fernando González ha scritto:
>>>> >> I hope it's interesting for some of you and, of course, any comments
>>>> >> of such an active and skilful community are very welcome. Mainly
>>>> >> because it's our very first development in python!
>>>> > Hi Fernando,
>>>> > it looks a very interesting development; thanks for this. Looking
>>>> forward to test it.
>>>> > How do you plan to integrate it into QGIS?
>>>> > All the best.
>>>> > Paolo Cavallini - Faunalia
>>>> > www.faunalia.eu
>>>> > Full contact details at www.faunalia.eu/pc
>>>> > Nuovi corsi: http://www.faunalia.it/calendario
>>>> > _______________________________________________
>>>> > Qgis-developer mailing list
>>>> > Qgis-developer at lists.osgeo.org
>>>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120618/ecfeafae/attachment-0001.html>
