[Qgis-developer] Unit tests failing - a heartfelt plea
Marco Hugentobler marco.hugentobler at sourcepole.ch
Mon Jun 18 08:54:22 PDT 2012
Hi Tim
The raster test passes now (at least on my machine).
Regards,
Marco
Am 15.06.2012 11:41, schrieb Tim Sutton:
> Hi All
> I just want to make a heartfelt plea that any new code pushed to Git
> master should not break tests (at minimum on the platform on which you
> are working). If you do radical changes, the test suite should be
> updated to accommodate them so that the tests still pass for your
> platform when you commit. I would like to see the test suite grow to
> encompass  as much functionality of QGIS as possible, but it will be
> very difficult to maintain them if we commit code that breaks them.
> You can always view the state of the last nightly builds here:
> http://dash.orfeo-toolbox.org/index.php?project=QGIS
> You can test your work before pusing it to master by doing:
> make test
> make check
> or (to share your test results)
> make Experimental
> Thanks!
> Regards
Dr. Marco Hugentobler
Sourcepole -  Linux&  Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
