[Qgis-developer] Announce: TauDEM plugin for QGIS
Alexander Bruy alexander.bruy at gmail.com
Fri Jun 29 11:30:16 PDT 2012
Hi all and sorry for cross-posting.
I happy to announce TauDEM provider for QGIS.
TauDEM [0] is a set of of Digital Elevation Model (DEM) tools for
the extraction and analysis of hydrologic information from topography
as represented by a DEM
An this plugin is a SEXTANTE provider plugin and allows to run
TauDEM command line tools directly from QGIS using excellent
SEXTANTE framework [1].
Plugin available from QGIS Official repository [2]. Before running
it please install SEXTANTE plugin first. As this is only front-end
you also need working TauDEM command line tools. Windows
users can use precompiled binaries and installation instruction
from project homepage [0]. For Linux users I prepare small
instruction in README.TauDEM file [3], hope this helps a bit
until packages for major distributions will be available.
If you found a bug or want to leave feature request please use
plugin bugtracker [4]
[0] http://hydrology.usu.edu/taudem/taudem5.0/index.html
[1] http://plugins.qgis.org/plugins/sextante/
[2] http://plugins.qgis.org/plugins/plugins.xml
[3] https://github.com/alexbruy/sextante-taudem/blob/master/README.TauDEM
[4] http://hub.qgis.org/projects/sextante-taudem
Alexander Bruy
