[Qgis-developer] Qgis-mapserver - SLD within WMS GetMap request
Alexandre Dube adube at mapgears.com
Tue Mar 13 10:08:38 EDT 2012
Marco,
   With the latest patch, the 1.7 branch now behaves as expected.
Thanks again,
Alexandre
On 12-03-13 08:05 AM, Alexandre Dube wrote:
> Hi Marco,
>   Gotcha.  I'll try the 1_7 branch then.  Do you have an approximative
> idea when 1.7.5/1.8 will come out ?
> Thanks a lot for your support, much appreciated.
> Alexandre
> On 12-03-13 07:04 AM, Marco Hugentobler wrote:
>> Hi Alexandre
>> SLD_BODY works in the developer version (master branch), but not in
>> the 1_7_4 version.
>> I've backported the fix to the 1_7 branch (don't know if there will
>> be a 1.7.5 or if 1.8, which already contains the fix, will be next ).
>> Btw, now that we have SLD support directly in the symbology classes
>> (thanks to Giuseppe!), I'm going to change QGIS server to use that
>> instead of the SLD classes in the server (they are still based on old
>> symbology).
>> Regards,
>> Marco
>> On 12.03.2012 21:51, Alexandre Dube wrote:
>>> Hi,
>>>   I'm using qgis-mapserv with QGis 1.7.4 on Ubuntu 10.04, using the
>>> ubuntugis-unstable package.
>>>   I'm currently trying to do a WMS GetMap request with a SLD_BODY
>>> parameter set with a simple SLD document.  Problem is, I always get
>>> the original style of the features defined in the .qgs file instead
>>> of the one defined in the SLD.  Setting a SLD parameter instead
>>> pointing to a copy of the file doesn't do anything either.  I looked
>>> around for clues but didn't find any.  I attached a copy of the SLD
>>> document in question (without a filter) and with with a filter.  My
>>> real test-case requires the filter and it's entirely built using
>>> OpenLayers.Format.SLD, so its content needs to be dynamic from a
>>> webmapping client application.
>>>   I already got help on IRC from Tim, and he mentioned that Marco
>>> should be the one knowing the answer to my issue.  SLD_BODY doesn't
>>> seem to be supported in qgis-mapserv.
>>> Thanks a lot (and a special thanks to Tim for his IRC support),
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Dr. Marco Hugentobler
>> Sourcepole -  Linux&  Open Source Solutions
>> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
>> marco.hugentobler at sourcepole.ch  http://www.sourcepole.ch
>> Technical Advisor QGIS Project Steering Committee
> Alexandre Dubé
> Mapgears
> www.mapgears.com
Alexandre Dubé
Mapgears
www.mapgears.com
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120313/23fe2b0c/attachment-0001.html
