[Qgis-developer] XY Tools
Richard Duivenvoorde rdmailings at duif.net
Mon Mar 19 15:49:30 EDT 2012
On 03/19/2012 04:59 PM, Paolo Cavallini wrote:
> Is there any special reason why GRASS point layers are not usable in XY Tools plugin?
> If I select one, it cannot be exported.
Hi Paolo,
I have a QGIS master here from the beginning of february, and that is
working fine with GRASS point layers. Both imported by shapes or newly
created point layers.
Did you try it also with an older version? The plugin just opens a layer
via the dataproviders...
You are referring to saving the attribute table to a spreadsheet file
isn't it? Without an x and y column, you cannot save it to a shapefile.
Regards,
I will compile master now to see if it still works after that
