[Qgis-developer] gsoc 2012
Nathan Woodrow madmanwoo at gmail.com
Wed Mar 21 18:36:36 EDT 2012
This SEXTANTE plugin is pretty bloody cool.  Is it possible to currently
use the plugin to do work, I can't seem to get any of the modules to pick
up that I have a layer loaded.
- Nathan
On Thu, Mar 22, 2012 at 7:05 AM, G. Allegri <giohappy at gmail.com> wrote:
> I have given a look to the code. Amazing work Victor!
> As soon as you stabilize it I will surely test it. Let us know ;)
> giovanni
> 2012/3/21 G. Allegri <giohappy at gmail.com>
> Paolo, SEXTANTE for QGis will be completely in Python, as you can see from
>> the code in source.
>> As Victor said, the algorithms hasn't been imported. He has reproduced
>> the "abstraction" of SEXTANTE, and at the moment the only algorithms that
>> have been imported are third-party (like fTools) and the bindings to SAGA
>> and Grass.
>> giovanni
>> 2012/3/21 Paolo Cavallini <cavallini at faunalia.it>
>>> Il 21/03/2012 18:18, G. Allegri ha scritto:
>>>> Ok, that's what I supposed. We're talking about two different things:
>>>> your framework and  the "geoprocessing framework" that started some time
>>>> ago. I don't know if Camilo (or others) are still working actively on that.
>>>> I can imagine that your experience with the "abstraction level"
>>>> development for SEXTANTE will be an important plus to the development of
>>>> such a framework... And I hope the development will converge on one of the
>>>> twos, otherwise it would a waste of resources.
>>>>  The main problem I see is that sextante is in java, and I believe it
>>> will be very difficult to introduce such an heavy dependency.
>>> All the best.
>>> Paolo Cavallini
>>> See: http://www.faunalia.it/pc
>>> ______________________________**_________________
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120322/26919b3d/attachment.html
