[Qgis-developer] crash on close without layer
Giovanni Manghi giovanni.manghi at faunalia.pt
Tue May 8 02:25:18 PDT 2012
I cannot confirm on both ubuntu 64bit and Windows.
cheers
-- Giovanni --
On Tue, 2012-05-08 at 08:05 +0200, Paolo Cavallini wrote:
> Hi all.
> If I close qgis before having added a layer, I get a segfault:
> warning: Can't read pathname for load map: Errore di input/output.
> [Thread debugging using libthread_db enabled]
> Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
> Core was generated by `/usr/bin/qgis.bin'.
> Program terminated with signal 11, Segmentation fault.
> #0  0x00007f33380216cc in QAction::setEnabled(bool) () from
> /usr/lib/libQtGui.so.4
> Anyone confirms? Worth reporting?
> All the best.
