[Qgis-developer] QGIS Server 1.8: empty map with VERSION=1.3.0
Bernhard Ströbl bernhard.stroebl at jena.de
Thu May 24 08:27:35 PDT 2012
Thanks Marco,
arghh, I knew there is this difference between 1.1.1 and 1.3.0
I was originally accessing QGIS Server from mapcache but there must have
been another issue.
Now all is working.
regards
Bernhard
Am 24.05.2012 17:10, schrieb Marco Hugentobler:
> Hi Bernhard
> If you switch the x/y coordinates, you also get an image with 1.3. In
> some cases, the coordinats are switched in 1.3 (usually geographical
> systems). Not a good idea, but that's what the 1.3 spec says...
> Regards,
> Marco
> Am 24.05.2012 16:30, schrieb Bernhard Ströbl:
>> Dear all,
>> another issue: QGIS Server is responding with an all-white map to a
>> GetMap when VERSION=1.3.0 is requested. Map is rendered correctly when
>> requesting VERSION=1.1.1
>> example:
>> http://map2.jena.de/wms/test?LAYERS=rule-based%20style&FORMAT=image%2Fpng&DPI=96&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A31468&BBOX=4459734.0425532,5639372.3404255,4481265.9574468,5646627.6595745&WIDTH=1012&HEIGHT=341
>> => white map, replace the version-parameter and you get a map!
>> QGIS 1.8 RC 1 (code version c367a35) on OpenSUSE 12.1
>> Bernhard
________ Information from NOD32 ________
This message was checked by NOD32 Antivirus System for Linux Mail Server.
http://www.nod32.com
