R: Re: Re: [Qgis-developer] from qgis.core impor * Windows problems
francescoboccacci at libero.it francescoboccacci at libero.it
Thu May 24 08:47:58 PDT 2012
Thanks,i will try all the choises and i let you know..Thanks
Francesco
----Messaggio originale----
Da: giohappy at gmail.com
Data: 24/05/2012 17.45
A: "francescoboccacci at libero.it"<francescoboccacci at libero.it>
Cc: <qgis-developer at lists.osgeo.org>
Ogg: Re: Re: [Qgis-developer] from qgis.core impor * Windows problems
Hi, i tried to run bat file (C:\OSGeo4W\OSGeo4W.bat), close ms-dos shell and run python
???If you close the shell you loose the environmental variables.OSGeo4W.bat sets env vars for the current shell, they're not kept as system env vars.
 You need those environmantal variables to leaverage the osgeo4w libraries.You ha mainly three choices:
 - run your python script inside a shell where you have setup the env variables (like it is done by Osgeo4W.bat)
 - hard code the environmental variables inside your python script and add them to os.environ, and set the path to the python modules with sys.path - make the various environmantal variables statically availables as system env vars (Control Panel -> Systems -> etc.)
giovanni
Data: 24/05/2012 17.15
Ogg: Re: [Qgis-developer] from qgis.core impor * Windows problems
Hi Francesco,are you using osgeo4w? In that case I suggest you to have a look to the startup .bat files (like C:\OSGeo4W\OSGeo4W.bat), that setup the right evnironment (python pat, bin dires, etc.)
In general you have to add the various Qt and Qgis DLLs to the PATH, and configure the python paths to be able to peak the qgis modules.
giovanni
2012/5/24 francescoboccacci at libero.it <francescoboccacci at libero.it>
Hi all,
i have a problem in my Windows PC. I try to use a python script that call qgis
modules.
I tried to do :
>>from qgis.core import *
i receive ImportError: DLL load failed ....
How i have to configure my environment variables to get these modules?
I try to find some solution on web but they aren't work.
Thanks
Francesco
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120524/0564477c/attachment.html
