[Qgis-developer] New plugin: Edge Densifier
Nathan Woodrow madmanwoo at gmail.com
Tue Oct 2 14:14:56 PDT 2012
Hey Alex,
I have approved the plugin in the main repo now.
Regards,
Nathan
On Wed, Oct 3, 2012 at 6:11 AM, Alejandro Aguilar Sierra
<algsierra at gmail.com> wrote:
> Hello:
> Some times you need polygons with denser edges. Your map looks fine in
> the 2D environment of QGis but when you need to convert your polygons
> to 3D meshes so they can be shown in the globe, long lines should be
> converted in arcs. A practical solution is just to add more vertices
> to long lines in 2D.
> You can use it by editing a polygon layer. I will appreciate any comment.
> It works with a dialog for which you have to know in advance the
> feature id and vertex index. I'd like to improve it in a way that if
> you are using the Node Tool, when you select a vertex, my plugin's
> dialog updates those inputs. Any idea?
> Another solution I would like is an automatic polygon densifier which
> add vertices depending on the length of the edges, not fixed like the
> current FTools densify.
> You can get the plugin from here until it is approved in the main repository.
> http://modelos1.atmosfcu.unam.mx/qgis/EdgeDensifier.zip
> Thanks in advance for any hint.
> Alex Sierra
> Qgis-developer mailing list
