[Qgis-developer] QGIS Server WFS-T integration
rldhont rldhont at gmail.com
Wed Oct 3 07:53:12 PDT 2012
Hi Marco,
I updated the QgsGeometry Class to add :
* fromGML2 static method
* exportToGML2 method
If you want to test QGIS Server Transaction you need to use the QGIS of
my branch, because I update the WFS provider to POST transaction with a
query_string (in the case of QGIS Server the map parameter).
Regards,
René-Luc
Le 03/10/2012 11:44, Marco Hugentobler a écrit :
> Hi René-Luc
> >For the GML, I'll update QgsGeometry class ?
> Yes, it will be good to have everything in one place (also for a
> potential redesign of QgsGeometry). But the GML methods should not be
> exported to the bindings, maybe you could add a comment in that
> direction to qgsgeometry.h.
> Regards,
> Marco
> On 03.10.2012 10:03, rldhont wrote:
>> Hi Marco,
>> I updated my branch with the definition of QGS_NAMESPACE and
>> OGC_NAMESPACE.
>> For Query_String, I found the code with a google search.
>> I test WFS-T with a jQuery XML POST and with QGIS.
>> Cheers,
>> René-Luc D'Hont
>> 3Liz
>> Le 03/10/2012 09:26, Marco Hugentobler a écrit :
>>> Hi René-Luc
>>> Thank you for this nice addition, WFS-T will certainly be a great
>>> contribution to QGIS server!
>>> I tried to compile the wfs_server_transaction branch, but it fails
>>> with the following error message (QGS_NAMESPACE and OGC_NAMESPACE
>>> are not defined):
>>> /home/marco/src/Quantum-GIS/src/mapserver/qgswfsserver.cpp:718:35:
>>> Fehler: »QGS_NAMESPACE« wurde in diesem Gültigkeitsbereich nicht
>>> definiert
>>> /home/marco/src/Quantum-GIS/src/mapserver/qgswfsserver.cpp:721:39:
>>> Fehler: »OGC_NAMESPACE« wurde in diesem Gültigkeitsbereich nicht
>>> definiert
>>> Maybe there is a commit that you did not push to github yet?
>>> Then, looking at qgswfsserver.cpp, it seems that most of the 2000
>>> code lines deal with GML. It would be good to separate that into a
>>> GML handling class on its own (which could also be used from
>>> qgswfsprovider, at the moment, the gml reading seems to be duplicated).
>>> In QgsPostRequestHandler, the code looks for the environment
>>> variable QUERY_STRING. I thought QUERY_STRING is only defined in
>>> http get requests and in post requests, there is only CONTENT_LENGTH ?
>>> Which WFS client did you use for testing (QGIS desktop)?
>>> Regards,
>>> Marco
>>> On 01.10.2012 15:21, rldhont wrote:
>>>> Hi all,
>>>> I need some review for the WFS-T implementation in QGIS-Server.
>>>> https://github.com/rldhont/Quantum-GIS/tree/wfs_server_transaction
>>>> This branche adds the capability to the QGIS Server to understand
>>>> transaction, adds a way to define which WFS layer can be editable
>>>> and if the administrator authorize insert and delete, adds an
>>>> enhancements for the WFS provider to support WFS-T which needs
>>>> extra parameters.
>>>> For the configuration on the WFS-T part, Update is possible if the
>>>> layer is publish as a WFS layer, Insert is possible only if Update
>>>> is possible and Delete is possible only if Insert is possible. You
>>>> can check Delete on a layer and it's automatically a WFS layer, or
>>>> uncheck Publied on a layer and all the checkbox are unchecked.
>>>> I have testing QGIS-Server transaction with an ESRI ShapeFile and a
>>>> Spatialite database. The both doesn't return a good FID, but only
>>>> Spatialite has persistent FID. The Spatialite provider probably
>>>> needs an update.
>>>> I test my QGIS-Server with QGIS and some JavaScript code.
>>>> René-Luc D'Hont
>>>> 3Liz
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
