[Qgis-developer] index in self.legend.groupLayerRelationship - different behavior between QGIS 1.8 and master?
Massimo massimo.endrighi at geopartner.it
Thu Oct 4 06:57:01 PDT 2012
Michael,
thank you for the tip but your code fails under some circumstances. See
attached image.
<http://osgeo-org.1560.n6.nabble.com/file/n5006430/lizmap_error.png>
If you think that you can fix it I will be happy to adopt your algorithm,
otherwise we can find a solution adding something to QGis API.
Regards
Massimo
kimaidou wrote
> Hi all,
> In Lizmap plugin, I need to display the layer and group tree. You can find
> some code here :
> https://bitbucket.org/mdouchin/lizmapplugin/src/9cdfa856b8f0/lizmap.py
> Line 451 : populateLayerTree
> There is some specific lizmap code in there, but you can probably use some
> of it.
> Michael
View this message in context: http://osgeo-org.1560.n6.nabble.com/index-in-self-legend-groupLayerRelationship-different-behavior-between-QGIS-1-8-and-master-tp5004337p5006430.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
