[Qgis-developer] python multiprocessing error in QGis (Windows)
Saverio Rutigliano saverio.rutigliano at gmail.com
Mon Oct 8 03:06:52 PDT 2012
Hi all,
I have this error when I try to use Manager() from python multiprocessing
library.
(Just start QGIS open Python console and execute the two following lines)
>>> import multiprocessing
>>> mgr = multiprocessing.Manager()
File "<input>", line 1, in <module>
File "C:\DEV\osgeo4w_dev\apps\Python27\lib\multiprocessing\__init__.py",
line 99, in Manager
m.start()
File "C:\DEV\osgeo4w_dev\apps\Python27\lib\multiprocessing\managers.py",
line 524, in start
self._process.start()
File "C:\DEV\osgeo4w_dev\apps\Python27\lib\multiprocessing\process.py",
line 130, in start
self._popen = Popen(self)
File "C:\DEV\osgeo4w_dev\apps\Python27\lib\multiprocessing\forking.py",
line 252, in __init__
cmd = get_command_line() + [rhandle]
line 339, in get_command_line
if process.current_process()._identity==() and is_forking(sys.argv):
AttributeError: 'module' object has no attribute 'argv'
It happens in both 1.8 and 1.9 dev version on Windows X. Of course
everything is ok using QGIS on Linux!... :P
It seems something related to the main Python/QGis process startup and the
way the library tries to start a new process.... but I can't figure out any
workaround.
Any idea?
Saverio
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121008/d5b64250/attachment.html>
