[Qgis-developer] Saving expressions
Paolo Cavallini cavallini at faunalia.it
Thu Oct 18 23:29:25 PDT 2012
Il 19/10/2012 08:21, Andreas Neumann ha scritto:
> What do you expect from the loading? Automatic application to the
> field calculator (sounds scary to me), or just the ability to choose
> from past expressions?
I meant the latter.
> To me the expressions do not have a natural 1:1 match to a layer like
> the .prj or the .qml file has.
Yes, but a list of the expressions used for that table would be useful
(and probably very easy to do).
> But I can see value in a central storage of expressions used in the
> past, regardless of layer and QGIS project. But it would just be used
> as a way to load and save expressions as templates to start from and
> not an automatic application to some calculation or the label engines.
> These settings should be better stored in the project itself rather
> than in a separate file.
This is not my original idea, but I agree it is an interesting
alternative, with its advantages.
Kind of a log of the expressions used per user is a slight variance of this.
All the best, and thanks.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
