[Qgis-developer] Merging of incompatible changes
Matthias Kuhn matthias.kuhn at gmx.ch
Thu Oct 25 00:25:23 PDT 2012
Hi all,
I don't know if somebody already brought up this (the discussion is
already rather long), but is there no possibility for including legacy
methods?
For the iterators this would probably mean, that there is a reserved
iterator running single-threaded for any calls to the old API.
I don't know what would be necessary to make a legacy string API.
This would bring us the benefits we need and leave old plugins running
(probably throwing out lots of big fat red warnings).
Regards,
Matthias
On Wed, 2012-10-24 at 23:38 +0200, Martin Dobias wrote:
> On Wed, Oct 24, 2012 at 10:38 PM, Marco Hugentobler
> <marco.hugentobler at sourcepole.ch> wrote:
> > Hi defs
> > Yes, the decision was that multithreading branch should be in 2.0.
> > Personally, I'm in favor of merging it as soon as possible (to give the dev
> > team enough time to get used to the new classes and to handle possible side
> > effects). Martin, is your planned merge already the full threading branch
> > merge or a part of it?
> Hi Marco
> First I would like to merge API changes that are required in order to
> get threaded rendering in place. I am trying to write unit tests so
> hopefully there won't be many regressions. After that I will be
> reintroducing threaded rendering. In case that we would find out that
> threaded rendering is not ready for prime time, it should be easy to
> disable it in order not to wait with 2.0 release just for it... so we
> should be still able to ship 2.0 sometime in spring/summer 2013 with
> or without threading.
> Martin
> Qgis-developer mailing list
