[Qgis-developer] QGIS infrastructure mindmap
Andreas Neumann a.neumann at carto.net
Mon Oct 29 01:39:39 PDT 2012
 Hi Pirmin,
 I removed the commercial support and QGIS associations and added the
 build servers.
 I added Paolo and you in the sharing settings so you can correct and
 edit the mind map. You should have received a separate email with the
 link.
 Andreas
 On Mon, 29 Oct 2012 09:11:05 +0100, Pirmin Kalberer wrote:
> Hi Andreas,
> Am Montag, 29. Oktober 2012, 17.33:04 schrieb Nathan Woodrow:
>> That is looking really good.  Nice to see where things are in
>> relation
>> to everything else.  Might be good to have the different build
>> servers
>> and some notes about who maintains them and their specs.
> The Linux builds are done in the www.(plugins/plant/hub).qgis.org VM
> (It's a
> single VM!). The Windows nightly builds are done on a internal
> machine of jef,
> AFAIK.
> I would conctentrate on the technical dependencies of the QGIS
> infrastructure
> and therefore remove the Commercial support componies, etc.
> Pirmin
>> On Mon, Oct 29, 2012 at 5:19 PM, Andreas Neumann
>> <a.neumann at carto.net>
> wrote:
>> > Hi Paolo,
>> > You can mouse over the little icons to the left of the text to see
>> the
>> > comments and the links.
>> > If you want to edit I need to register you as an editor (in the
>> sharing
>> > settings).
>> > Andreas
>> > On Mon, 29 Oct 2012 07:57:41 +0900, Paolo Cavallini wrote:
>> >> Il 29/10/2012 02:44, Andreas Neumann ha scritto:
>> >>> Hi,
>> >>> At the HF in Essen I promised to create a mindmap representing
>> the quite
>> >>> distributed infrastructure. Here it is:
>> >>> http://app.wisemapping.com/c/maps/81444/public
>> >> thanks Andreas!
>> >>> I tried to add URLs and comments with a short explanation and
>> the
>> >>> responsible administrators.
>> >> I can't see that, possible?
>> >> All the best.
>> > Andreas Neumann
>> > Böschacherstrasse 10A
>> > 8624 Grüt (Gossau ZH)
>> > Switzerland
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
 Andreas Neumann
 Switzerland
