[Qgis-developer] Points from polygon's geometry vertices
Dominik Fröhlich dominik.froehlich at venus.uni-freiburg.de
Mon Oct 29 07:58:36 PDT 2012
Hi again!
Maybe you could also help me with an other issue: I need to save the
coordinates of the polygon vertices to a list for later processing. I
tried with "thepoints = thepoly.asMultiPoint()" but get an empty list.
In the API Documentation I found that the function asMultPoint() needs a
MultiPoint-geometry as input (what makes no sense to me, as I don't need
to convert it if it is already MultiPoint…?).
Is there an other function that does what I want, or am I calling the
asMultiPoint function wrong?
Regards and sorry for disturbing again!
Dominik
On Mon, Oct 29, 2012 at 12:26 PM, Dominik Fröhlich
<dominik.froehlich at venus.uni-freiburg.de>  wrote:
> Der QGIS developers,
> I'm trying to write a python plugin to reate input data for one of our
> models. It basicly converts three shape files with special fields to a text
> file.
> I have a buildings vector (polygon) layer containing three polygons (which I
> created for testing). This layer is called "build" in the code. To extract
> its geometries, I wrote a little function:
> def extract_poly_geometry(self, layer):
> feature = QgsFeature()
> geom_list = []
> while layer.dataProvider().nextFeature(feature):
> geom_list.append(feature.geometry())
> return geom_list
