[Qgis-developer] Python ogr driver issue (was ----> (no subject))
Tim Sutton lists at linfiniti.com
Mon Oct 29 13:31:33 PDT 2012
Hi
On Mon, Aug 27, 2012 at 9:32 AM, ludo <ludovic.granjon at wanadoo.fr> wrote:
> Hi
> Ok so I try your script Tim and I obtain this :
> Application state:
> Prefix:        /usr
> Plugin Path:        /usr/lib/qgis/plugins
> Package Data Path:    /usr/share/qgis
> Active Theme Name:
> Active Theme Path:    :/images/themes//
> Default Theme Path:    :/images/themes/default/
> SVG Search Paths:    /usr/share/qgis/svg/
> User DB Path:    /usr/share/qgis/resources/qgis.db
> Could not find OGR provider!
> When I do
> for i in r.providerList():
>     print i
> I have
> delimitedtext
> gdal
> gpx
> But the same in the python console of QGIS :
> \etat de l'application :
> Prefixe:            /usr
> Chemin de l'extension :        /usr/lib/qgis/plugins
> Chemin vers les donnees :    /usr/share/qgis
> Nom du theme actif :        default
> Chemin vers le theme actif :    :/images/themes/default/
> Chemin vers le theme par defaut :    :/images/themes/default/
> Chemin SVG:        /usr/share/qgis/svg/
>         /home/ludo/.qgis//svg/
> Chemin vers la base utilisateur :    /usr/share/qgis/resources/qgis.db
> and
> WFS
> gdal
> gpx
> grass
> grassraster
> memory
> mssql
> ogr
> osm
> postgres
> spatialite
> wms
> Do you know where is the problem ?
Does:
ldd /usr/lib/qgis/plugins/libogrprovider.so
show any library issues when run from the same environment as where
your standalone script runs?
Regards
Tim
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
